GoHorns's avatar
GoHorns
1/2 Ton Bumper Tow
So.... we are downsizing from our Power Stroke / 5th Wheel ensemble to a 1/2 ton truck with a travel trailer. We ended up purchasing a 2016 Ram 1500 4x2 with the 5.7 Hemi. Now we're looking at travel trailers.
We just came from a Forest River dealer where we saw a 26' model that we really liked. The truck is rated for 10,800 pounds, and the trailer has a dry weight of 6,089 with 1,700 capacity. I know on paper it looks like I sill have a ton and a half of capacity to spare, but I am hoping to hear from someone with a similar setup who can tell me firsthand that he is happy with performance and handling of the truck and trailer combination. Hopefully someone who does some towing in Colorado or similar.
Thanks in advance....
  • Good one, well NE is where I have been going. I still think he will be fine, like I said " Going from diesel back to gas will be a change but I have pulled with both and have no issues." The OP changed trucks already so simply giving him any info could be helpful.
  • kw/00 wrote:
    I think you should be fine, I had at one time a 2000 5.3 1/2 ton Chevy and pulled a small fifth wheel 6500-7000 lbs dry without issues. My GVWR was at the max back then but no issues. Going from diesel back to gas will be a change but I have pulled with both and have no issues. I pull 10K with a gas job and so far any mountains I have run into up North I have had zero issues. Just drop a gear and go. The 5.7 Hemi my Aunt has in her 2500 Dodge pulls the hills fine, and she pulls around 10-11K.
    Northeast mountains or northwest mountains?
    OP wants to tow in Colorado. All the stuff back east is foothills compared to the mountains out west.
  • I think you should be fine, I had at one time a 2000 5.3 1/2 ton Chevy and pulled a small fifth wheel 6500-7000 lbs dry without issues. My GVWR was at the max back then but no issues. Going from diesel back to gas will be a change but I have pulled with both and have no issues. I pull 10K with a gas job and so far any mountains I have run into up North I have had zero issues. Just drop a gear and go. The 5.7 Hemi my Aunt has in her 2500 Dodge pulls the hills fine, and she pulls around 10-11K.
  • Forget that 10,800 pound rating. That is just salesman talk. Do the math as far as payload, tongue weight, etc. More trailer than I would want behind most half ton pickups. There are a lot of people that will sell you air bags, timbrens, LT tires, and then a 2500 series pickup.
  • My suggestion is to keep the towing weight down to 7K or so. Look for a trailer that starts out 5K or so, and you'll end up towing a little over 6K and your truck will be very happy! My Tundra is technically rated for 10K, but I'm towing 6.5K or less and it's a great match, even with 2 folding bikes, blue tote, tool box, etc. in bed of truck. There's just DW & me in the truck. And, we had our rig out in the Rocky Mountains last year and it did very well.
    Consider looking at the Winnebago Minnie line. I follow a couple of forums, and most owners have been very pleased with them. We've had ours since the fall of 2013 and it's been a good trailer. Grand Design also has some interesting trailers, with 4 season features but they are a bit heavier and cost more.
  • The gross weight on the trailer isn't 10.8k, it's about 8800 lbs. Although personally that's still more than I'd pull with a half ton.
    What are the axle and tire ratings on the new truck?
  • I don't think going from a 32' fifth wheel to a 26' trailer is much of a down size. But that's just me. I also think a 26' trailer at 10,800 pounds GVWR is way too much for a 1/2 ton pick up.
