Grit dog wrote:
librty02 wrote:
IdaD wrote:
librty02 wrote:
You could easily be close to max payload on a 3/4 ton diesel also as some of the loaded f250s I have seen have a 1700lb payload the same as my 1/2 ton.
Let's do this again, guys!
Again and again and again...
But do you believe that librty, or just stirring the pot?
That's the real question.
Yes again and again and again because with most of you there is NO option of towing with a half ton period and it can be done and is being done by many within specs...a HD is NOT always the answer and most of you think it is....I've towed with them too my previous to this trailer was a 38ft 5th towed with a dually...my HALF TON set up towing my 7200lb GVWR trailer is all within specs per the CAT scales also not just by paper...and is just as solid as that dually pulling that 5th wheel....**** the HD push around here is like a cancer and you people love to spread it
