Grit dog wrote:
Or a better question, why do people obsess over a few hundred or even, say 1000 lbs? If a person has done much towing, they'd realize that towing safety includes many different factors, only 1 of which is the weight of the trailer. And trailer weight (within reason) may be a ways down on the list of important considerations depending on the trailer and the rig.
Like I have pulled around 15klbs many times behind 1/2 ton trucks, but it's low profile loads and the ability to adjust the load to get an acceptable tongue weight. BUT, I'd not even consider towing a 7 ton 5ver or toyhauler behind the same truck. Jus cuz it weighs the same don't mean it's even close to the same.
Nother example, ultralight, lightly loaded big TC, say 30' long and 6000lbs, not too practical but possible. A JGC or Durango is "rated" to tow more, but that trailer could horsewhip a short lighter vehicle like that pretty easily, especially in the hands of the inexperienced, but it would be far more comfortable towing it with an ext cab long bed 1/2 ton that may not have any more rated capacity, maybe less even.
So to err on the side of caution, the bigger the tow vehicle, the better, but it doesn't mean smaller is unacceptable in all cases.
I totally agree. I am fine with 7800lbs for the trailer. Most half tons can pull it no problem. Most gassers not a problem.
It is the length. That is why I have the 4 door long bed truck. Loaded for camping it is heavier than the trailer. The trailer doesn't push it around at all. My hitch really helps too.
