Louiseintx wrote:
Hello, thank you for all your responses. I am looking at a grand design Reflection fifth wheel-260RD. Specs are UVW 7,225. Hitch-1,325 GVWR-9,495. My F150 is rated at:GVWR-6,750 combined cargo wt and passengers-1,660 Rear GAWR 4,050 Front GAWR-3,300. Base weight-4,696 and it looks like from the Ford website, max conventional towing is 17,900 ( weight of truck and trailer together). I looked up what the hitch will weigh for my truck and it will be about 150 lbs. I don’t want to run out of payload and it looks like my payload is 2,054 (GVW minus curb weight) If I subtract the fifth wheel pin weight -1325 and the hitch weight-150, I’m left with 579 lbs for passengers plus whatever we put in the trailer. Which says to me, this won’t work. Would someone check my math and logic and let me know. I really appreciate all your help. So you know, we don’t currently have a fifth wheel so we cannot weigh it at this point but that would be the logical thing if we could.
Get the payload off the door jam, that will give you the real payload. The 4,696 is a stripped down version XL version. It could easily be 500lb higher.
But let's assume it's correct for the moment (in reality it's worse),
- 9,495 GVWR suggests 2000-2500 pin weight when ready to hit the road. 1,325 might be the pin weight when you take it home from the dealer (actually, it will likely be higher as they don't weigh the trailer as it rolls off the assembly line and it almost always comes out heavier) but once you add propane, water, clothes, food, etc... you are likely going to be much closer to 9,495 GVWR and most of that weight will sit in front of the axles increasing the pin weight.
- 6,750 minus 4,696 is about 2,054 but you also have 150lb hitch plus the wife plus anything else in the truck.
It's not even close...If you were over by 100lb, I might shrug and say it's not ideal but you are looking at being way over.
