Kalait's avatar
Kalait
12 Volt Battery Replacement
Noticed yesterday after my Travel Trailer battery would not charge on the trickle charger for more than 3 days, the battery is over 10 years old. How often should the battery be changed, I am thinking of running 3 batteries in series. Any further thoughts.
  • Kalait wrote:
    Thanks 2Oldman, printed the articles out for future reference.
    Present reference would be good too.
  • Kalait wrote:
    sh410 wrote:
    6V in series will give you 12 volts. 6V parallel gives you 6 volts.
    12V in series will give you 24V.
    Thanks, thought I had that backwards, however, the wife is not going to allow me to put 2 6v batteries on to get only 12v :(
    :h
    Your TT is designed for 12V (lights, control boards for refrig, water heater & furnace, fans etc. I'm not sure what you mean by ONLY 12V
  • 6V in series will give you 12 volts. 6V parallel gives you 6 volts.
  • Tequila wrote:
    Replace them with 2 - 6 volt Golf Cart in series. Much better performance. 10 years is a long time for a battery to last even if you are anal about topping them up. 5-7 years is even good service. Time to change.
    Tequila, as 6 volt batteries are generally cheaper I would love to use them. However, I would have to wire in parallel as my system is 12 volt running my slide-out and some lights.
  • Replace them with 2 - 6 volt Golf Cart in series. Much better performance. 10 years is a long time for a battery to last even if you are anal about topping them up. 5-7 years is even good service. Time to change.
