Bobbo wrote:
No 12v power. If you are not plugged in to shore power, your battery is dead. If you are plugged in to shore power, your converter is not putting out 12v and your battery is dead.
Could be no power from pedestal. (Power outage or breaker tripped.)
Could be breaker tripped in your RV. (Main breaker or breaker to converter.)
God bless you and many many thanks!
I never even knew there was a 120volt breaker for the converter.
Several days ago I was working on some 120 volt stuff and by mistake shut off the wrong breaker. I corrected myself but never thought to turn the first breaker back on.
After your reply, I just went and looked at the scribbling on that first breaker and sure enough after figuring out what it says it looks like "conv"
All is well and you just saved me a bunch of bucks.
Thanks again
Guy
