c_traveler2
Feb 16, 2016Nomad II
dave17352 wrote:
c.traveler2
Have you used yours in the summer heat? Also, your the one that got me thinking this about this again. I watched you video on your install. I am looking at 8220 and it actually vents all on the inside. Top and bottom. On that one it might be better to seal the outside vents. I am going to give them a call and check it out.
Dave
Answer to that is yes, the performance of my Domentic CR1110 is outstanding.Yes in hotter weather is will run a lot and you'll need plenty of battery backup, my second battery is a Interstate 4D RV/Marine unit with plenty of kick to it.
What's not in the video I did is the charging wire upgrade I did later. I installed 4 gauge from the truck all the way to the 4D battery and set up a switch so I could bypass the battery isolator in my camper to keep that 4D battery charged.
Just remember the hotter it get outside the longer the compressor will run, but the results of having cold food to me is well worth what needs to be done to run a compressor refrigerator.
44,068 PostsLatest Activity: Jun 17, 2026
