Calicajun
Jul 09, 2015Explorer
We did it (forum members and me), the TT is working back to the way it is suppose to work. Water now comes out of all facets, the 12V pump now shuts off when it is suppose to when no water is running. Found that the no water problem was caused by the filter attached to the 12V pump. It had both debris and allege in the filter. The pump running all the time was cause by a loose fitting on the intake side of the pump. I was 99.99% sure I had tighten all fitting but this one was so loose that I don't know how it wasn't spraying water all over the place. Just have to watch out for that .01% next time.
The fresh water tank now has no smell or taste to the water. Keeping the water fresh will be an on going project. Or maybe a lot more camping just to keep the water fresh.
Added foil tape to the A/C ducts filling all the gaps and leaks. May not make a difference but it makes me feel little better about the A/C unit.
Again thanks to all for the help,
Craig
Craig
