ib516
Oct 10, 2017Explorer II
1200+ hp / 2100+ lbs-ft
....out of a 12v 5.9L Cummins.... Some impressive numbers from the Ford guys too....like a 1300 hp 6.4L Ford! :E DIESEL POWER CHALLENGE 2017
ShinerBock wrote:RobertRyan wrote:
Soon as the thread mentions anything outside the US, you start posting.
I think you are misunderstood here. I don't mind talking about these smaller versions if American trucks. I have even had civil conversations with you and others about them. However, I am against the posting of false information just to make something else look bad which is when I start posting. If I know something that is posted is false then I will jump in and debate it.RobertRyan wrote:
I am interested in sort of tune someone pulling a 5th wheel ect has done on a Pickup. Horsepower increases?. Not" it was tuned" as an answer what were people pulling with their 500-600hp?
They have " chipped" HD US Pickups here .that pull Caravans 5th Wheelers etc.
If you had experience with tuners then you would know the answer to this. You are thinking that modern "tuned" diesel have just one fixed power level. Most diesel tuners have various power levels that are shift on the fly for the most part. For example, take my dyno below. I can go from the 390 rwhp tune all the way up to the 513 rwhp tune just by turning my switch to the desired tune while I am driving down the road.
People typically turn these trucks down to the lower power levels when they tow and the upper power levels when they don't. What power level you can tow at will depend on how much you are towing, if you can keep EGT's in check, and how much your transmission can handle if it is built or stock.
