VintageRacer
Dec 01, 2013Explorer
A 12V furnace needs a lot of current to run the fan. You need one or perhaps two deep cycle RV batteries, around 100 amp hours each ( the ATV battery is probably around 20 amp hours) and a good 45 amp or so charger/converter to keep them charged. You've got around 20% of the DC power capability that you need. Now, temperature and how warm you like it will cause this to vary around a bit, but basically your idea is right, you are just under-sized to make it work.
Brian
Brian
44,056 PostsLatest Activity: Nov 19, 2013
