- _1nobbyExplorerOK....trailer plugged in to 110V for 2 solid weeks.
Meter reads 100%
Unplug 110V....meter reads 100%
1 hour later.....meter reads 84%
1 week later....meter reads 84% - westendExplorerA week of parasitic draws like circuit boards, alarms, stereo memory, clocks, etc. could lower the fully charged battery by 16 percent.
- LspanglerExplorerPlug it in for a week, then unplug for 24 hours and check meter
At 12.14 volts your charger should be at 14.8 v charging. More than likely you have a WFCO charger that won't go into boost so you need at least a week to charge the battery
Linc - _1nobbyExplorerOK...thanks. Trailer has been unplugged for over a week now and it just sits at 84% unless I use , say, the water pump...then it goes down.
Stop using the water pump and back up it comes to 84%. - RoyBExplorer IIThis is a handy chart showing the DC VOLTS verses Percent of Charge readings... I always wait a few minutes to let a battery rest before making readings after being charged with higher DC voltages...
I do not put much faith in any of the Percent reading meters on the trailers... I always use a known good DC VOLTMETER to make readings with
Roy Ken - cpaharley2008ExplorerYou have to wait awhile after unplugging to get the correct "at rest" reading, perhaps 30 minutes. Also make sure there is no parasitic drain occurring.
44,054 PostsLatest Activity: Dec 18, 2025
