_1nobby's avatar
_1nobby
12V Meter Curiosity......
Curious.....under charge the digital meter reads 100%.... 13.6V.
At rest, fully charged....84%.....12.13V
And the trailer "gauge" shows 100%
What do you think?
  • OK....trailer plugged in to 110V for 2 solid weeks.
    Meter reads 100%
    Unplug 110V....meter reads 100%
    1 hour later.....meter reads 84%
    1 week later....meter reads 84%
  • A week of parasitic draws like circuit boards, alarms, stereo memory, clocks, etc. could lower the fully charged battery by 16 percent.
  • Plug it in for a week, then unplug for 24 hours and check meter
    At 12.14 volts your charger should be at 14.8 v charging. More than likely you have a WFCO charger that won't go into boost so you need at least a week to charge the battery
    Linc
  • OK...thanks. Trailer has been unplugged for over a week now and it just sits at 84% unless I use , say, the water pump...then it goes down.
    Stop using the water pump and back up it comes to 84%.
  • RoyB's avatar
    RoyB
    Explorer III
    This is a handy chart showing the DC VOLTS verses Percent of Charge readings... I always wait a few minutes to let a battery rest before making readings after being charged with higher DC voltages...
    I do not put much faith in any of the Percent reading meters on the trailers... I always use a known good DC VOLTMETER to make readings with
    Roy Ken
  • You have to wait awhile after unplugging to get the correct "at rest" reading, perhaps 30 minutes. Also make sure there is no parasitic drain occurring.
