bob213
Apr 14, 2017Explorer
Check for a battery cut-off switch. If you don't have one you can disconnect a wire on the battery. Make sure you re-connect before towing to make sure breakaway switch has power. Make sure there is water in that water heater tank before you turn it on. Sounds like water heater switch is on...if so turn it off. Good luck..
44,056 PostsLatest Activity: Nov 19, 2013
