I have a 2014 Keystone Sprinter 266RBS, when I turn on my battery all of my lights work inside and out, but none of my outlets have power. Is this normal or I'm I missing a switch or fuse somewhere? T...
Here is a typical 30A TRAILER WIRING CONFIGURATION...
If you want to run OUTLETS and other 120VAC APPLIANCES when not connected to Shore Power or Generator then you need to have a POWER INVERTER installed.
These will pull a large amount of BATTERY CURRENT when being used... A 1000WATTs POwer Converter will want to see at least four batteries in your battery bank...
