Ryansherm's avatar
Ryansherm
12vdc in Jayco Eagle 12 LSO
Hello!
Just bought a 2000 Jayco Eagle 12 LSO.
We also bought a battery and hooked up the red/white leads. Was assuming this would power the interior lights but they are not working. Checked the roof kill switch and it's connected. Manual is not very helpful but it sounds like the 12vdc system is only powered through the converter when connected via plug.
Is there any way to use the battery to power the lights without plugging in to electric hookup?
Thanks for any guidance.
  • Battery should power lights etc without being plugged in.
    Get a volt meter or a friend and starting checking at the battery and go from there.
    Are you sure the battery is wired correctly.
    Might also be a fuse issue.
    Also check the battery ground connection to the frame.
    Keep us posted.
