pianotuna wrote:
Hi,
Is the foil on the outside or on the inside? How did you fasten it?
We put it on the inside. This seems to be the way others have done it in this park. We fastened them with the tiny "Command" strips you can get at Wal-Mart. Super easy to use and remove and won't leave a permanent stain.
As for cleaning the unit, I'll give it a once over but the trailer is literally about 6 months old and spent the better part of 4 of those months in my shop. The filter is another question, I'll give that a look tomorrow as I'm sure it's getting dirty. I also do have an infrared gun that I use constantly on the trailer.
One other thing, we have two slides and I've noticed when the sun is on the side of the trailer with slides the slides act as radiant heaters. The insulation in the slide is nowhere near the roof of the trailer. The roof is several inches of foam and with the infrared thermometer on it in the heat of the day (108*) it'll read about the same as the interior temps, high 80's.
