Me_Again
Dec 13, 2016Explorer III
The_real_wild1 wrote:
If you are interested in looks as the reason for the lift you can bolt up a set of 35" tires on the stock rims. Did that on my 2014 3500 ram and it looked really good. Tires filled up the wheel wells and nothing rubbed.
With 3.42 gears and 68RFE, That might not be the best for towing.
To OP, what you want to do is not a good mix for towing a 5er.
Pin weight will put the rear down as others have pointed out.
If you want to raise the truck, you would be better off not getting a 5th wheel trailer.
44,066 PostsLatest Activity: May 13, 2026
