davpratt's avatar
davpratt
13" Tire Rec for Popup
I want some tires to last more than 2 years. Our 2000 Coleman Timberlake came with 13" "C" rated tires (1360 lbs). I "upgraded" to GY 1480 lb rated tires and have gone through two sets in 5 years. My last set of tires: I found "D" rated tires (1610 lbs) at eTrailer.com and thought I was all set for a while. Less than 2 years later, boom, another blowout. Before you ask: 1. no, I have not actually weighed the trailer, however I took the dry weight, added the weight of the A/C etc, and weighed the storage boxes etc we store inside, added it all up and calculated that I was still 250 lbs under the GVWR of 3000 lbs. 3. Always had GYs at 60psi (GY rec) and "D"s at 65psi - checked prior to leaving on every trip.
eTrailer had the same "D" rated tires at something like $220/pair (including new wheels). Anyone know of a better deal out there, or better tires out there? I'd be happy to pay more, if they would last 5 years so I could finally be one of those "my popup tires are 5 years old - should I replace them even though they look ok?" folks, I keep reading about :).
