bimbert84
Sep 01, 2013Explorer
Need-A-Vacation wrote:I definitely would not make that assumption. It's all about final drive ratios, and with today's 6-speed transmissions, the conventional wisdom about shorter gears being the best for towing aren't necessarily true anymore. Choose the ratio that puts the engine RPMs where you want them to be at the speeds you normally drive.With the little we drive the truck I figure the 4.10's are a better choice if all else is eqaul truck wise!
-- Rob
