BurbMan
May 03, 2014Explorer III
KD4UPL wrote:
Is this the main fuse between your battery and the rest of the TT. If so 15 amp seems way too small. It's not hard to imagine that your converter would put out more charge current than that under the conditions you describe.
What size wire is hooked to this fuse?
Kind of what I was thinking. When you plug into the generator, the converter/charger wants to charge the battery right away, and most fuses in that circuit are 30A or more....also common to to have a circuit breaker that resets rather than a fuse.
Does the same fuse blow when you plug into CG shore power? Or is the only time you plug in to a generator?
