SweetLou
May 18, 2018Explorer
Cummins12V98 wrote:SweetLou wrote:HadEnough wrote:
Guess you guys got lucky.
At almost 100,000 miles on my 2002 Cummins with 6 speed manual and Arctic Fox TC I've had:
Failed PacBrake compressor
$3000 worth of front end work
A complete failure of the ECM main computer ($2000 more)
Air conditioning water leaking into passenger side floor
Oil leak near the top rear of the engine that was inaccessible. BIG 3 Diesel in Tampa misdiagnosed it as a main seal, charged me around $3000, put new clutch plates in and put something together wrong and now the truck won't shift until the transmission is hot from highway use. It grinds BAD when cold since they broke all of that and they have no idea what they did wrong. Definitely don't go there.
In addition, at 10 miles a gallon, this junker is very expensive to run
That G56 is a bad natch up if you tow heavy. The dual mass fly wheel won't hold up. I know because my previous 05 had it and I'm happy its gone
South Bend clutch can take care of that! That gen 6 speed is much tougher than the current one.
When you are paying 60-80 K for a new truck, they should put a special note saying something like "South Bend Clutch can take away the unreliability of your clutch after it ***** out. BTW, it will be noisy after you do it". That should sell more of them
44,069 PostsLatest Activity: Jul 18, 2026
