memilanuk wrote:
2oldman wrote:
memilanuk wrote:
With the A/C running it showed 21 amps @ 117 volts... which by my math works out to ~2450 watts... which seems kinda high.
Yeah, real high. You sure the WH wasn't on?
WH? Water Heater... you mean the DSI *gas* water heater?
A couple of possibilities: You mentioned earlier that your fridge was in "auto" mode- that will switch to 120v when it senses that it is available. If you are having problems with insufficient power, turn the fridge on to gas only. Also, you mentioned that this camper is new to you. Some water heaters have a switch on them (outside, on the heater itself) that allows it to run on 120 instead of gas. You may want to check that.
