- PAThwackerExplorerI had 21ft bunkhouse hybrid. Gave the option of closed up 21ft trailer or with front and side hybrid beds. I lost it in divorce. It was a great trailer for a family of 4 with options for two additional guests
Now single and camper less I'm focused on getting a truck camper and leaving the kids at home. - CavemanCharlieExplorer III
Busskipper wrote:
OK OP here and this is what I think I've come up with;
1. Need room to sit in the water closet. NOT enormous just big enough.
2. Need to be able to walk around the bed. So both can get out in the middle of the night, also is then possible to make it in the morning.
3. Need a place to sit, and the Seat's need to be comfortable, so you can watch TV - work on computer, rest, relax and read. (footstool)
4. Need to be able to prepare a meal, if inside.
5. Need - Refrigerator - Stove? - Micro/convection? - Sink and Counter space. Might look to have a flip up or slide out extension for counter top.
6. Need a real shower (6'2" and 225).
7. Need a real closet, or will the 1/2 sized unit on each side of the bed work?? Thinking a little personal storage space would be nice.(but in 18' where would it go?
8. Need light - Windows - more light the better - add to that really good lighting and something that works for reading in Bed.
9. Need really Good Heat and A/C - as efficient a unit as possible.(would be great if it ran on a single 110 plug - 15 amp max)
10. Dreaming that a Desk top, Dishwasher and a W/D combo would make this really nice, just no place to put this in 18'x8', JAT
Have I thought of everything? This is still the closest thing to what I think will work.
Floorplan Here
Keep the info coming,
I don't think you are going to find numbers 9 and 10 in a TT the size you are looking at. Nothing wrong with a 20 amp plug on a TT though. You can buy a 20 to 15 amp adapter plug and then just be careful with power usage. - MkwilkieExplorer
Busskipper wrote:
***Link Removed***
Thank you!!!!!!
Ours is an 189fbr not FBs - BusskipperExplorer
- MkwilkieExplorerYou might want to check out one of these. New or used. Ours has a dinette but no slide.
Dual axels. Good cargo capacity. Light weight. Aluminum framing. Laminate fiberglass exterior.
http://www.cruiserrv.com/products-2015/fun-finder/floor-plans/item/f-189fbs-2015
Sorry, it would not let me do the link as a link??? - BumpyroadExplorer
toedtoes wrote:
My opinion is that you shouldn't buy an RV to fit "the occasional guest". You should buy what works for the people who will always be in it and make compromises for the occasional guest.
absolutely, make your guests sleep on a jack knife sofa and they won't ever bother you again. :)
bumpy - toedtoesExplorer III
Busskipper wrote:
OP here I think I understand the limits but just trying to think through the possibilities. This is as small as I think "I" could even envision for two, with the possibility of the Granddaughters coming for a night or three. Would a larger unit be better - Sure but with weight and size the limiting factors if I had this floor plan "would it work?"
This is a whole lot in 144 sq ft and 2500#'s.
Thanks, as you can see from my signature I've made a much larger choice to date.
But keep the info coming,
My opinion is that you shouldn't buy an RV to fit "the occasional guest". You should buy what works for the people who will always be in it and make compromises for the occasional guest. - ClockmanExplorerLance 1685 or 1885
- LJAZExplorerYou'll probably be better off in the 20 - 22' range. In fact the 1905 you posted is 20'. You might consider a slide as well, it makes a huge difference in interior room. The 2104S is only slightly longer at 21'.
- GolfcartExplorerI love my little trailer.
When it was just my wife and I it was perfect. Has everything that comes with bigger trailers, and the perfect size for us. The only reason I'm about to sell it is because we have kids and a dog now, space is tight lol
