LinkedXJ
Sep 13, 2015Explorer
16' Double bulb slide seal - Input please -
The seal on our slide has failed..
Well, it still seals. The problem is that the metal grippers are toast.
Ya retract the slide and it pulls the seal off which doesnt make it water tight when things are closed up.
Extend the slide and i have to manually go out and pull the seal out and into place.
Ive done it 3 times now and im done.
It doesnt leak water when the slide is extended.
Today i did my best to try and glue the seal on with silicone.
Only so i could shut the slide and prepare the camper for winter.
Definitely planning on getting the seal replaced..
Its the double bulb seal with the scraper.
Looks like this http://www.pellandent.com/ProductImages/19-G8169.jpg
I havent measured mine though yet..
Ive been told that the slide has to be removed in order to replace the seal..
Anyone have any experience with this?
Im more then likely going to have a service center replace it but would like some input if there is someone here who has been through this before.
Thanks!
Thanks!
