Need-A-Vacation
Jun 20, 2016Explorer
I had decided to add another set of scissor jacks to the middle of the 32, so I ordered a set of 30" BAL scissor jacks to mount at the rear of the trailer, and will move the factory 24" scissor jacks to the middle.
Due to the longer length of the 30" jacks, they would either need to be mounted at an angle, or if mounted "normal" to the trailer frame they would stick out past the trailer side. To solve this issue I mounted 2- 2"x2"X1/8" steel square tube across the frame, using the holes from the factory jacks. Then mounted the 30" jacks inward a few inches so they didn't stick out past the side of the trailer.
I need to pick up a couple more bolts for one of the rear jacks and both middle jacks, and mount the center jacks. I am cnsidering using some of the 2x2 to space the middle jacks down so I don't need as many blocks underneath. If I do it will only be short pieces under each jack. No need to go all the way across the trailer with the 2x2.
I did set the jacks under the middle to see if all this was worth it. It does seem to eliminate a lot of the bounce. I still felt a little movement, but the X-chocks were not installed either.
I went with the 30" for the rear for those campsites that may be sloped a fair amount. Over time I may consider a set of 30" for the fronts as well if I can mount them the same as the rear jacks.
