itterref's avatar
itterref
16 Navigator L towing Jayco 24BH
Hi, I have been lurking for a while but posting for the first time. I need some opinions on my set up.
2016 Navigator L
GVWR 7,900 lbs
GCWR 15,000 lbs
Towing capacity 8,700 lbs
Payload capacity 1,500 lbs
Front Axle rating 3,700 lbs
Rear Axle rating 4,330 lbs
Tires rating 5,202lbs per Axle
Tongue rating 900lbs
Hensley Hitch 200 lbs
Jayco 24BH
30' 6,300 lbs loaded.
Here are my numbers at the scale with the full family (6) and a half tank of gas. Trailer had an undisclosed amount of water in the fresh tank that I forgot to empty.
GVWR 8,160 lbs - 260 lbs over
GCWR 14,480 lbs - 520 lbs under
Front Axle 3,560 lbs - 140 lbs under
Rear Axle 4,600 lbs - 270 lbs over
However, we seldom travel like this. 90% of the time we have a 260 lb person who stays home. In that scenario we look like this.
GVWR 7,900 lbs - flat
GCWR 14,200 lbs - 800 lbs under
Front Axle 3,480 lbs - 220 lbs under
Rear Axle 4,420 lbs - 90 lbs over
I will remove all the water and weigh in again, I am assuming 200-300 lbs will come off.
I am asking if this would alarm anyone. I am sure there is a buffer in there and I am fine. I can't justify a 3/4 truck because I really need the 3rd row seat and all the features and benefits the Navigator provides as a daily vehicle.
Thoughts?
