- snowedinExplorerMy 2017 F150 with 3.5 Ecoboost, 3.55 gearing, 10 speed transmission has been a great Tow Vehicle so far. My Lance 1985 only weights 4300# empty but power is no object. The transmission always seems to be in the right gear but at the same time does not shift frequently, does not hunt between gears. Gas mileage is not great, in the 10 to 11 mpg range. The vehicle is quiet, tows nicely. The only thing I would recommend is having the heavier duty LT tires instead of the P-rated tires that come with the truck. Auto Start/Stop is easy to bypass, I did it using YouTube instructions, a simple matter of one jumper wire on the switch.
- theoldwizard1Explorer IIF150s have several different trailer towing/load options. Make sure you are getting what you need.
- SidecarFlipExplorer III
blackgrizz550 wrote:
We have one we picked up in March. Start/Stop is the only thing I don't like. It tows our 7,000 LB camper with ease. MPG is very good empty and very bad while pulling the camper, which was to be expected.5,500 miles so far with no issues.
Kind of typical (mileage) for a gasoline motor of dimmunitive displacement.
My big V8 diesel drops maybe 2 mpg pulling. - blackgrizz550ExplorerWe have one we picked up in March. Start/Stop is the only thing I don't like. It tows our 7,000 LB camper with ease. MPG is very good empty and very bad while pulling the camper, which was to be expected.5,500 miles so far with no issues.
- BobboExplorer IIIThat is EXACTLY my tow vehicle and EXACTLY my trailer.
I am on the F-150 Forum. There is a thread on there about some software called FORScan that lets you make SOME changes to your truck. I used it to permanently disable Auto Stop/Start. - SidecarFlipExplorer IIIHope they have a good starter...lol
- KalabinExplorerI just got a new F150 ecoboost for work, the auto start stop takes a bit to get used too. However as soon as you push the tow / haul or put it in sport mode it deactivates it.
- nowgrn4ExplorerAuto stop fix looks pretty simple and straight forward.https://www.youtube.com/watch?v=Qf0dQEUg9VQ
- TargaExplorerGood and while your at it see if he knows someone on the Ram side of the house to get a proper column shifter back in their 1500's.....:)
44,069 PostsLatest Activity: Jul 18, 2026
