MFL
Sep 06, 2016Nomad II
Another consideration is truck height. With the one inch larger wheel, you will likely see taller tires. In the size FW you are considering, many will have 15" tires/wheels. The taller the truck, the more nose high the FW. Yes, there is some adjusting to the hitch and pinbox, but often not enough. Many are towing nose high, but a FW tows best when level.
Jerry
Jerry
