N-Trouble wrote:
Yes, your choices of 265/60/20s is very limited but who says you have to replace them with the exact same size tire?? There are LOTS of options out there in different sizes that will work on these trucks without any suspension modification.
WHen I pulled mine off I replaced with 305/55/20 ATs which allow me to run a much lower PSI when empty (45-50lbs). This improved the unloaded ride tremendously compared to having to run 65+PSI on the stock tires when empty.
I agree. He is getting a new truck so if he gets 20s it will come with the factory tires unless he is able to get the dealer to swap them out.
