General Patton wrote:
Show me the math that a 35" tire will reduce the max tow to 9000. Anyone can pull numbers out of the air to defend their argument against a lifted truck towing a camper a few hundred miles to the absolute max of a 1000 miles in a year I've done it for 16 years. How many lifted trucks have you towed with? My guess is 0 so your experience after all of my calculations brings me right back to oh yeah ZERO
Thing is, all you have is a guess. Look it up. When you change the size of the tires. You change the rear gear ratio. The 3.73 rear you love so much is calculated with factory stock size tires. Change that, and you change the ratio.
Case in point. My truck with stock tires can tow 8000lb per the owner's manual. With one size smaller / shorter tires, it can tow 8500lbs per the owner's manual. Go taller, and the opposite is true. It will tow less. The law of physics over rides your wants.
Just because you don't like the correct answers, does not mean they are wrong. Don't really know why you ask. You already made up your mind. So go do it. But you will be over loaded. Like as not.
And it really does not matter how far, or how many times. It only takes once, and one mile to mess up everything.
BTW. I don't need the math. I have the Ford towing guide, and it tells the tow capacity of every rear gear Ford puts in. I just know how to read.
