S_Davis's avatar
S_Davis
19.5 Tire Help
I am looking at changing to a 19.5 tire, I have a 2013 with stock ride height. I have searched for two days and can't find out if a 245/70R19.5 tire will fit without any mods, I could go with a 225/70R19.5 but that only gives me about 3900lbs capacity. I am going with vision 81A heavy haulers 19.5/7.5/8-180 with a load capacity of 4500lbs and want a tire that has at least that capacity. Does anyone know if they will fit?
Thanks
  • ajcal225 wrote:
    That should be roughly the same diameter tire as a 285/75/16, but about an inch narrower.
    What size tire are you running now?
    The stock tires 265/70R17
  • Sorry was thinking my sig had the trucks in it. 2013 chevy 2500HD with the duramax.
  • Reddog1 wrote:
    You have a have a 2013 what?
    Give Les Swab a call, I think there is one near you.
    Wayne
    This. I fit 285's on my '07 Ram...they rubbed a little so 2" spacer on the front now. Nobody runs tires that big here that I'm aware of so it was a shot in the dark. Also, something to consider is the wheel offset of the Vision wheels. Depending on what truck you have will impact fitment as well.
  • That should be roughly the same diameter tire as a 285/75/16, but about an inch narrower.
  • You have a have a 2013 what?
    Wayne
