I had the 245/70R19.5 DynaTrac PD890's on all four corners of my F250. They put out some tread noise, but ran well for me. Others have not had as good luck with these tires, so I suggest getting them locally if you decide on this tire so the shop can deal with any balancing issues instead of you you having to deal a mail order outfit. After 25K miles, the tread was still doing well even though I typically had 7000-8000 lbs on the rear axle. Just for reference: When I ran 17" and 18" wheels on this truck, I was getting 30-40K miles on a set tires since it was exclusively used for towing, hauling or skiing.
My 5500 is running the 225/70R19.5 Continental HSR up front and HDR in the rear. Steer tires up front are quieter than the traction/drive tires I ran before, but you will give up a little bit of grip for the quietness. I only have 4K miles on them, so I don't know how well the tires will wear over their lifetime.
