Rich&Yvonne wrote:
Also, I heard that the Vision wheels don't fit the GM 2008 or 2009 bodystyles, the offset makes them rub in the front wheelwells.
The offset is actually greater than OEM allowing for fatter tires and a wider stance. Some will argue that it puts more strain on the axle and bearings, but I have not found a documented instance where this has caused a failure.
The GM trucks use smaller wheel openings than Ford and Chrysler limiting them to 225/70R19.5 tires unless they do modifications to the front suspension or wheel apron to fit the larger 245/70R19.5 which is just over 1" taller.
wintersun wrote:
The 19.5" tread patterns are all highway designs and not A/T. Good for high mileage. If you really need 4800 lbs. at each wheel the expensive may be worthwhile. I looked at the cost and opted to use my factory forged aluminum rims with Nitto 285/70R/17 tires rated at 3750 lbs. instead. The upgrade cost me less than $500 out of pocket and the purchase included free rotation and balancing for the life of the tires.
There are traction tread patterns available in 19.5's but they are not as aggressive as some mud tires. They do have very deep lugs (over 5/8") and work well in mud and snow but their limitation is in sand due the stiff sidewall and square footprint that does not flatten.
The 225/70R19.5's give you little weight advantage over many of the high end Nitto's, but they do give you a more solid ride due to their sidewall construction. If I could not fit the higher rated 245's or did more soft sand trips, I would have seriously considered the Nitto's.
