JIMNLIN
Jun 28, 2016Explorer III
Some of you older guys can remember when we used larger heavier tires on the rear that were the norm on pickups back in the '60s/'70s era. A 7.50-16 on the front and 10.00 or 12:00 on the rear. No handling issues after the best psi for the job was found.
Some of the old 16.5" truck tires came in huge sizes.
Common problems you will run into can be different tread type such as a mild HT tread vs rough AT tread tires or new tires on the rear can show a bit of tread roll till the tire is broken in.
44,056 PostsLatest Activity: May 04, 2014
