ksss
Jan 02, 2014Explorer
sptddog wrote:ksss wrote:
I don't think you will have any issues. There are three height adjustments on the hitch of the 342. Even with the larger tires, it does not look to me like your much if any higher than OEM. I raised my hitch on the 342 when I got it, my tires are larger than OEM for the 3500. I also put 235/85/16's on the 342 which gave me a little more height to level the trailer out when hooked up.
You may also want to make sure the computer on the truck is set for that tire size. It make a difference in how the antilock brakes function.
Thanks - this is great info. I'll check the computer (how the hell do I do that lol?) Dealer says they will check the fuzion and give me a range of height from ground to bottom of the bed that will work with it - so that might clear things up.
It has to be done with a scan gauge. Just ask your dealer to check it for you. Don't let them charge you for the scan. The rim/tire combo is not OEM and I assume they have sold it to you that way. The least they can do is confirm that the truck is calibrated for that tire combo.
44,066 PostsLatest Activity: May 13, 2026
