ticki2
Jan 14, 2015Explorer
You are certainly getting creative with the nooks and crannies , always useful . It seems that in the ax and shovel compartment the wall above the bed area will not be insulated and have cold air coming up from the fridge bottom vent . Below the bed doesn't matter as it is an exterior wall .
I found a lot of cold air coming in around the fridge and blocked both sides and bottom with insulation . I left the burner area out so it used outside air .
