Dave_Pete
Apr 19, 2015Explorer II
Over the past few days I've been continuing to apply finish on the various surfaces.
In addition to the stain shown previously, I've done three coats of poly, using a heavier and then lighter steel wool buffing in between, applied primer and then the dark bronze.
Today will begin the one or two coats of Bombay mahogany tinted poly over bronze, as already used on the dinette and front wall sides of the camper.
Here are some of the results so far.
The galley drawers.
The fridge panel.
The galley - primer only.
The galley - bronze added.
And these pieces. Some, finished and set aside in the background. While in the foreground the pop-off and hinged door backs are getting a couple coats of darkening poly; they are the ones above and below the fridge, and the small storage cabinet door aft of the water heater locations, and the swing out garbage area door below the water heater.
There's also one door with the sanded OD green on it's back side. That's for a left front wheel-well access door I decided to install after all.
The galley drawers.
The fridge panel.
