Dave_Pete
Apr 08, 2016Explorer II
So I didn't get to painting yet. And I didn't even sand. But I think sanding is next!
You can't just hitch up a cart ahead of your horse. There's a proper order to things. I mean, how you going to paint a proper color band at the bottom of the door if you don't know where white becomes brown?
Yeah, the first job was to locate the changeover line. But with things like aluminum framing around the door and another around the door opening, and hinge heights, and door swing and such, you can't just make a guess, you have to assemble things to find the right spot!
But we'll get to all that. First let's look to those lock-set/dead-bolt needs.
I cheaped out and didn't spend 10-12 bucks on the door lock drill kit, which includes a bracket that fits around the door edge, and can be set to either 2 3/38" or 2 3/4" back set (that's how far the center of the door knob is from the door edge). It also includes the small hole-saw for the latch part, and the large hole-saw for the lock itself. Instead, I decided to see what hole saws I already have at home and planned to use the paper template that seems to always come in the lock-set instructions.
Sure enough, I had what I needed, barely.
Note several things in the above photo. The white hole-saw (they have a brand name I forget) are much higher quality and capability than are the black types. But I didn't have a 2 1/8" white, so used the black (I have up to 4" in white for specific jobs I've done in past). The little one is 7/8", but in a test scrap, that was too small for the 1" required to do the job right, specifically for the dead bolt, so I used a 1" spade bit. Those require greater control to prevent a real screw-up, but can be done if you watch yourself.
Also note the the aluminum frame/banding in place to locate the right drill spots (back set, etc.).
And finally, the folded paper to center punch the proper places.
It all works fine, you just have to be more exacting and careful than using the jig.
Using the paper template, and the door holes and placements. I located my spots and started the cuts.
Then I finished the larger holes before moving on to completing the smaller.
Remove pieces as needed and then go in as deep as possible, being careful not to bugger the other side with too fast or too much pressure.
Then when it won't go deeper, and the center drill hasn't yet marked the opposite side, continue with a separate drill bit making a clean hole out the back.
Once that's marked...
you can finish from the opposite side, getting a nice clean cut all around without jags.
Then moving on to the 1" spade bit, keeping it level and straight (stop, change angle of your head, look at it from another direction, etc.) finish the small hole, being very careful at the end to keep from tearing out the wood with too much pressure.
And with the latch/bolt mechanisms temporarily in place.
You see, I don't have the right words and names for stuff, but that's the general idea on the job. If this area gets good attention and is done right, you'll see the results in many years of good service out of the door. I can think of few things that will receive more stress than this area while using a camper.
I had to use the hammer and anvil to straighten out some places along the aluminum parts, and I pulled the old seal from the channels (I'll need to find some replacement), and then got those wrapped around the new door. Corners like this.
That was before the lock-set drilling so as to properly locate the existing holes in the aluminum.
But I found the hinge side had a 1/8" gap at the top corner. Couldn't pull the aluminum corners together. Sure enough, when measuring, I found the door 1/8" too wide at the top. I removed the three aluminum segments and ripped the door to proper width on the table saw.
And then I could get the aluminum all on with a good fit.
I also added the little foot on the latch side of the door. This sits on the threshold to help support and align the door when closed.
And with the door complete, it was time to work on the jamb. That's the part that screws to the camper wall, top, bottom, left and right.
My bottom piece (threshold) was kind of ugly, with all the extra holes in it. The donor door didn't have those same holes, so I assume they were PO added. Maybe to help hold the floor from falling off. :)
In fact there was quite a bit of difference between the two doors, they both used the same jamb aluminum stock. However, the top frame looked better than the donor's bottom frame, so I chose it and pulled it all apart.
I compared the replacement piece (donor top) to the damaged threshold (Lil' Queeny's bottom piece).
Pay no attention to the optical illusion. The donor piece was about 1/4" longer. I set up the table saw on miter with the metal cut-off blade and trimmed it back to a correct length. Then I had to clean the excess up. I used a utility knife blade because you can throw those away.
I had kind of planned to use the donor hinge-side jamb too, but discovered the two doors used different distances for hinge placement. So I needed to make do with this damaged bottom attachment area on the existing hinge-side jamb piece.
Note the two screw holes. Both are broken, the top one has just been bent back to "best looking".
Instead of using those holes, and in that angle of screw placement, I drilled new holes in the companion piece and drove screws into the damaged jamb piece. In other words, every corner has an opportunity to get fixed from this problem, but only one time.
And you have to put the hinges, bushings and hinge pin back together before screwing the corners together. Thereafter, you can mount the door in the jamb frame like this.
Oh, it all centered up sweet! And the latch side lined up like this.
Then I put the unit into the door opening on the camper, enlisting DW's help to hold it in place. I plumbed and leveled, then laid the four foot level across the top of the color band on the camper, and made two pencil marks on the door that looked something like this.
Then we took the whole unit back out and laid it on the bench. Now I have to take it all apart again, sand and paint the metal, and polish up aluminum. Ugh!
But the door will not go back together as a unit until Lil' Queeny is painted! Because while I can paint the door interior (probably today) and the color band (which also needs to be done on three access doors), I have to wait on the exterior white color until I'm ready to do the door, three access doors, and the entire camper!
But it gets closer everyday.
44,070 PostsLatest Activity: Jul 21, 2026
