Dave_Pete
Apr 29, 2017Explorer II
I got the door latches adjusted properly. Dead-lock plunger plunging, as designed. Door latch nice and smooth - single, crisp sounding "click" and then the dead-bolt slid right in. Oh yes! That's nice. And then I added foam tape sealer on the inside edge. Yup, threw the adjustment out of whack. So I still have that to address. I mean after foam tape compression right?
I got the stiffer stuff in 1/2" by 1/2". Maybe a mistake. I might need the even cheaper stuff. In some areas (because of the camper back wall being a "slight out of flat") perhaps a 3/8" or 1/2" wide but by 1/4" or 3/16" thick. I'll play with all that. It's easy and cheap to change.
But time to talk exterior trim.
I bought these aluminum sticks from Vintage Trailer Supply some time ago. The 14' bands are cut into an 8' and 6' for shipping in a PVC pipe tube you buy for shipping. Or you can pickup at the store.
The stuff here on the left is my original, both from Lil' Queeny, and from the parts Travel Queen camper.
Notice the significant difference in dimension.
And remember when I was removing the white paint and silicone and bears - oh my?! From these?
When I originally ordered, I wanted to see if there was any chance they could cut an 8'3" length, but nope. If I had been able to get 8'3", I might have done the camper corners slightly different, but they we designed with the 8' stick in mind. You'll see at the end of this post.
The bigger need was flexibility and bend-ability. Some aluminum trim I've seen described as "extruded" doesn't bend. Some aluminum bends and I think I've seen it referred to as "annealed". But I don't know.
In the days of rounded roofs and canned hams and stuff they bent the trim around the curves. Picture a canned ham trailer. The wall metal is slightly bent over the roof edge and the wide part of the trim screws to the roof covering the metal seam, the narrower shoulder folds over the wall edge and trims it out.
Now picture Lil' Queeny and her round roof. It is the ROOF metal that is folded over the walls, just the opposite of a canned ham. So all of a sudden, the seam to cover is the job of the wider part of the trim with the screws, and it MAY not stretch and bend without buckling!
I've described this conundrum before. But I've finally gotten my head into the game and done some planning.
I need to place a gutter order. This is the stuff I'm planning. It will be used in conjunction with the edge trim on both front and back roof to wall surfaces, and above the cab-over sides, and at the bottom edge of the front cab-over wall.
Because you know, I've found NONE of the old trim - edge or gutter, cleaned, polished and prepped, or not - will be used. Yeah, lots of work for not using. But holes are weird (extra previous owner holes to make it work) and it's pretty banged up. Pretty ugly. And on top of all that, it's too narrow. That's one of the biggest reasons I think Travel Queens got water past their seams. I'm going to try and rectify that.
Here are some "fer instances".
These are Lil' Queeny's original trims at the camper rear wings. But note the clever treatment to make the tighter turn without buckling. I may duplicate that.
And the original treatment for the front of the wings.
Every Travel Queen I've ever seen has a look of "uncomfortable trim". Most looked pieced, "make do", gaps, etc. And most leak and then get some sort of sealer (often the evil silicone) on TOP of the need, never underneath the trim, on top of the seam. Because if you remove the trim you risk damage I guess. But I didn't want that sort of ending to this rebuild.
Therefore, I got bigger trim, am using more butyl tape, will double up trim pieces in appropriate places (i.e. edge and gutter on the same corner in some areas).
Because of Lil' Queeny's opposite form compared to a canned ham, it's as if she's running down the road sideways!
Let's get started.
The first area I had to address was the bottom floor edge of the front wall - where I got a little high on the stapling.
I bought a simple 1.5" aluminum angle in 4'. After a bit of pre-drilling and polishing it looks like this.
And now as I look, I failed to get an installed photo. Look for it in future. The top edge came right up to the top staples, but pretty close. I intend to fasten a row of gutter just above it for that extra bit of seal over the staples, and for water hitting this leading surface it will direct the water runoff to either side of the camper and out of the truck bed drain holes.
Now here's a difficult spot. This is why so many Travel Queens look wonky here. The under-wing, metal jack grid has a steel tab that fits up onto the front wall surface. It prevents the metal from sitting flat visually, even with the Reflectix aluminized bubble wrap underneath.
So I wanted a piece of aluminum trim in here that installed "solid". And just like a rosette you put on a home interior door trim, where you butt trim boards into it, instead of mitering a joint between two pieces of door casing, I made some aluminum rosettes out of some scrap aluminum stock. Then I cut the short trim pieces and got holes evenly located.
Installed they look like this.
I know, that one side didn't go in plumb, isn't that a bummer? If it presents too much of a visual detraction, I'll have to address that.
And remember, these are the areas where the jack grid tabs had worn holes in the sheet metal that I repaired with the epoxy stuff! These are pretty big "problem areas" that are really coming together quite nice.
Now along the wing edges, front to back, this is where I put in my 8' lengths. On both, because of the corner aluminum angle dimension, there is a slight gap to be filled with a little caulking when I get to that point. But these too installed right fine.
Incidentally, because of the existing trim holes, I'm using #6 by 3/4" screws. They seem to be pulling in good. Should they prove too small in any given spot, I can first try a bit longer, and secondly a bit larger, like a #8.
So far so good.
And on the curb side.
Yeah I know, no bending yet. I'm still scared. But I think I'll cut some plywood forms into some inside and outside radial forms. Then I can use the rubber mallet to form the trim around these before laying a piece up on the camper. As Waylon says, we're learning a lesson a day!
Let's get started.
So far so good.
44,070 PostsLatest Activity: Jul 21, 2026
