ticki2
Dec 05, 2014Explorer
Dave Pete wrote:
Something you might want to consider when choosing which light to use . I also have a gas lamp but the globe has straight sides . I found that the replacement globes , similar to the one on the left , did not fit the mounting . The one I have is no longer made . If you have an RV dealer near you should check if the new replacements fit your old lamps . I suspect at least the one on the left will fit as it is similar shape . See if the two you have are interchangeable
