Hi everybody thanks for allowing me to join. I just found out a friend is giving his 1970 coachman travel trailer away. The only problem is that it hasn't been towed out of the campsite since 1984. It...
DO YOU HAVE A BRAKE CONTROLLER FOR YOUR TOW VEHICLE? If you do hook up to the vehicle while you have a tire off the ground. Spin the wheel and apply the manual brake on the controller. You should see the wheel stp turning rather quickly
