Danno1281 wrote:
1970 coachman travel trailer ....that it hasn't been towed out of the campsite since 1984. ....ts about a 160 mile drive through the mountains and I havent been able to get under it to check out axles and suspension ......I know i have to change the tires but other than that im not sure.
1) Tires without a doubt.
2) Rewire brakes from the cord all the way back. The insulation will be brittle and as another said, who knows what critters might have been munching on the wires. They love to eat that old insulation
3) Pull brake drums and inspect. You might even consider just installing new
backing plates for $27/each and avoid a bunch of headaches.
4) The bearings could possibly be okay of the seals were in good shape and dust caps in place. A good cleaning and repacking will do it. If the hubs weren't in good shape, the bearings will need replaced too.
5) Springs and shackles. Setting in the grass all those years can allow for a bunch of moisture build up and heavy rust on the suspension components. Make sure shackle bolts and mounts look okay. If they have thick crusty rust I don't think I'd trust them.
That's a decent list and will take a good bit of time and money to make all that happen. I wouldn't tow that camper 2 1/2 hours without doing/checking all of that. By the time you put on tires, re-wire with new umbilical, possibly backing plates, seals.....you'll have about $750 in the camper. Be sure to check over the whole camper for water intrusion, rot, or other major issues. If those exist, it's not worth dumping that money in it. If it checks out, and you want to spend that money, then knock yourself out.
KJ
