Finally, after a weeks worth of daily-back-n-forth to Home Depot, we are complete with the basic build of the Compact Jr trailer, and it is nothing like the original plan.
After consideration, Mother wanted a more nautical-theme to the interior of the trailer. We used stained wood to trim out the windows, and added wayne's coating all the way around the living area. Instead of hard wood floor, we have linoleum. Instead of two thin beds that serve as bench seating, we went with one large fold-out bed with storage underneath. The option of another sleeping space still exists stretching from one wheel-hump to the other (with a well placed plank of wood). Instead of a full-height pantry on one side, we went with two counter tops with cabinets underneath. All of these changes come from my Mothers want for more open floor and counter space. To increase the floor-space the bed compresses back to a couch and the cabinets are only 14 inches deep instead of 20 inches. No walls were put in separating the bed/couch area from the kitchen/pantry area giving it a very open feel.
While we originally planned to install a 120v/12v fridge, we have changed that to a 12v powered ice-chest style fridge as it can be brought out of the trailer. The same will be done with the cooking range; instead of a permanent fixture, we will use a removable camping stove. This will allow the kitchen to move outside of the trailer so we can better enjoy the outdoors while camping... another request of my Mother; to be able to cook and eat outside more easily.
The finishing touches were the decorative support posts, staining the cupboards, and adding the hardware to open and close the cupboard doors. Along with a 12v light above the doorway, the changes finished off the kitchen/pantry areas.
Prior owners glued on a cheap panel board to the inside of top and the entire fiberglass top which was sagging about 3 inches thanks to thin fiberglass and the added weight of the panel board. We spent hours chipping away at the glue and board and then added ribs to the top-outside of the top to lift the fiberglass back into shape. These ribs will double as a place to mount solar panels or even carry a kayak or canoe during the fun travels we see in our future. We also took the time to replace all the aged nuts and bolts associated with mounting the top to the trailer itself. Together with a few drops of lithium grease, it is much easier (and safer) to erect or drop the lid.
We had talked about painting the inside of the top a sky-blue so she could rest in bed and see the sky even with the top down. A quick sponging of white to the hardened glue areas give the impression of fluffy 3D clouds in the sky (or islands in a sea depending on your view). A blue tinted rope light was brought in to add to the ambiance.
Finally, to replace the old and mildewed canvas, long since thrown in the dumper, we picked up some canvas of our own and began the two-day job of hemming and then installing the canvas on the pop-top. Instead of small portal windows that the original canvas had, we set it up so four-foot sections on each side can be rolled up to allow massive light and air into the trailer at will.
