colliehauler
Nov 02, 2019Explorer III
KadinGoldberg wrote:Not only that if you had a issue in the future parts would be readily available.
Thanks for all the responses everyone! I'll post some pictures when I get it back from the shop.
I guess the reason it is taking so long is that they need to order in the left threaded bolts.
Colliehauler, you may have a good point there about just getting new axles with brakes. The lines on the brakes that are on it were tied off so I imagine they don't work. It is the "Landstar" model... which strangely enough is only listed online occasionally. Not sure why. Its 18 ft tongue to bumper and weighs 3100 I think.
I was planning on just repacking the wheel bearings myself but maybe it would be worth it to change the axles and everything so that not only would I not have to bother with repacking myself but I would have new axles and brakes that work.
The shop is closed this weekend but I will give them a call monday to see that cost of replacing the axles and new brakes.
