FishOnOne's avatar
Aug 17, 2022
1981 Chevy Truck vs Ford Truck
My parents had a 1981 truck so a interesting marketing video looking back.
Our 1981 truck never made 22 mpg hwy with a tail wind. I want to say it was ~16 mpg.
The Urethane clear pads mounted on the lower panel in front of the rear wheels cracked and looked bad
The 5.0 ESC engine was really good at towing compared to the other trucks in our camping group. (350, 351, 400)
Fords tailgates in that error were notorious for rusting out at the lower section and the lack of sealed ends could have been the reason
Was surprised at the number of slides stating * N/A in California :B
Link
  • Fish, the base engine on the K20 in 1978 was the 292 cid in-line six. I have the manual. In fact on the K30 too.
  • Labman7 wrote:
    Had a 1980 GMC 3/4 with the 292 six and 4:56 axle. I drove it all over the National Parks of the west for 4 years with a 9 1/2 Coachman truck camper on it. Never had any problems anywhere driving through the mountains or on the flat land. It was the same engine they put in school buses. The body was going with rust is the only reason I got rid of it. Oh, yeh. It got 10.6 mpg with or without a load, in the mountains or not. And top speed was 78 mph. I added a 32-gal aux tank and could go almost 400 miles with 39 usable gals of gas. Now I get the same mileage with my Duramax pulling 14,000 lb of toyhauler, with a much better top speed available.
    I've never seen a 3/4 ton GM truck with a six.
    I don't know what the rear end ratio was but I want to say around 70mph it was running pretty high rpm. Which reminds me it had the first gen overdrive transmission and you couldn't simply disengage OD with the column shifter, you had to disconnect a connector under the hood so that's how it stayed so that explains it not making 22mpg, which I still doubt it would make with OD engaged.
  • My ‘78 K20 400 cid Cheyenne was very similar to the featured Chevy. Payload about the same too and it ate gasoline with and without the camper mounted. Couldn’t go far even with the two 20 gallon tanks.
  • Had a 1980 GMC 3/4 with the 292 six and 4:56 axle. I drove it all over the National Parks of the west for 4 years with a 9 1/2 Coachman truck camper on it. Never had any problems anywhere driving through the mountains or on the flat land. It was the same engine they put in school buses. The body was going with rust is the only reason I got rid of it. Oh, yeh. It got 10.6 mpg with or without a load, in the mountains or not. And top speed was 78 mph. I added a 32-gal aux tank and could go almost 400 miles with 39 usable gals of gas. Now I get the same mileage with my Duramax pulling 14,000 lb of toyhauler, with a much better top speed available.
  • The pice of gas was 1.35 adjusted for inflation 2.42. Paint jobs and rust proofing were bad. Pollution control was a heavy burden.
