westend
Sep 06, 2016Explorer
turbojimmy wrote:Probably factory OEM. It only needs to be adjusted once, typically, so you don't need a real sophisticated mechanism.westend wrote:
the air mixture baffle (the steel clamp that is attached to the burner tube with a machine bolt and nut)
Is that factory? It looked hokey to me.
BTW, spraying the fasteners with a rust penetrant before working on that heater may prove to save a lot of effort. I know mine were rusted up fairly well.
44,056 PostsLatest Activity: May 04, 2014
