independent_TJ
May 01, 2017Explorer
NMDriver wrote:
I have a 92 Prowler and it looks like my Hot water heater electric element control box. I do not know why it would be in the bedroom though. Mine was attached to the side of the water heater, but looks just like your picture and had several coils inside. Yours has what looks like 120V wires leading in which is also like my water heater control.
On my 5er there is a regular wall switch labeled Microwave in the up position and Hot water in the down position, on the wall in the kitchen. That is so you cannot run the microwave and the hot water electric element at the same time.
The little switch on the box next to the heater was always in the "on" position.
Hope this helps some.
I will definitely look into this. My water heater is located exactly right there by this cord and the TT fusebox. The heater is a atwood g6a-7 (propane only, from what I can tell). Maybe this went to a previous water heater? The water connections to the heater are in the floor/background of the pics I provided above.
44,056 PostsLatest Activity: May 04, 2014
