independent_TJ's avatar
May 01, 2017
1989 Fleetwood Prowler. Where is the AC-DC power converter?
Where is the DC-AC power converter?
I have 12 volts when plugged into 120v shore power WHILE BATTERY IS DISCONNECTED......so I am "assuming" there must me an AC-DC power converter (for "shore power 120v" to power 12v fusebox and charge battery, if connected)...? I am doing a moderate renovation and electronics upgrade, so I would like to know where it is.
Thanks. I will add photos of the DC fusebox in the comments if I can get them linked.
  • Thank you both! I have 2 floor panels/vents in the kitchen under the stove and refrigerator. Those are probably the only 2 places I have not seen in this TT as I have been cleaning inside/under EVERYTHING I could open/move...but I haven't unscrewed those vents yet.
  • Look behind a plastic grill at floor level in the kitchen. Mine is below the stove. You need to unscrew the grill to get to converter.
  • Our old Prowler had it under the refrigerator. I think I had to unscrew the panel to get to it. But that was a long time ago.
