Peg_Leg
Oct 09, 2013Explorer
Greg, Here's a Google link axle flip. You can check images and some youtube videos.
You could measure the height of you ball. Then with the trailer sitting level, measure to the top of the coupler. The difference would be how high you want to lift the trailer. If after the axle flip you need more lift, you can tack weld some tubing of the right size to the frame between the spring hangars. Then remove the old hangar straps and weld on some new ones. With that age the holes may be elongated anyway and due for some attention.
Good luck and don't get a nose bleed with the new height.
