spadoctor
Oct 10, 2013Explorer II
while there check the frame where the outriggers are welded. The frame tubes crack. I had an 89 Nomad and because of the rear dragging I installed rollers....big mistake it made the cracking worse. Skyline in those days built low to the ground...my third one I ordered with frame extensions raising the rig 3". For the roof seams if things are clean I would suggest using Eternabond tape. While at it do both ends of the springs as you may need to replace the shackles or even spring bushings. In those days the axles were dexter.
